I put a cheap cab enclosure on my Axis this winter. I had to remove my mirrors to install enclosure. Would have to either cut hole in enclosure for mirror or leave them off. I left them off. I ordered a $30 backup camera with monitor and installed. Plugged into 12v power port and powered both the camera and monitor. Ran cable up around rollcage. In a couple of weeks I'll take enclosure off and put mirrors back on. But I think I'll keep the camera.
  • Jamesjoh changed the title to Side by side mirrorsKemimoto
    • By Jacob E freeman
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By Polish DIY Lover
    • By shawn b
    • By Chucky 1
