By fishhouse3
This machine is ready to go and needs nothing - just hop in and hit the trails! I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
By Kingfish
By great8redsfan
By hdtran
Hy (pronounce he), just bought a Hisun Sector E1.
I'll be using it to haul logs and stuff in the Sangre de Cristo mountains.
By Robert B
Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
