Good day all,
searching here but cannot find the answer,  Hisun been working fine and now reverse limiter seems to be engaging and cannot back up, cannot find a clear solution to disable the limiter. found a possible relay?  not sure which one or to cuut a wire at ecu but a picture or diagram would be helpful
thank you for any help in advance
Not famlar with that model, but most hisuns being very similar: can you try unplugging the box under the hood labeled "speed limiter"?
If there's not a box, I believe there is a wire you can cut, but I don't know the details, I believe "motorcycledoctor" has some info on disabling the speed limiter on older models in their info part of theor site.
  • alevins changed the title to 2008 HS700 reverse rev limiter
They used to have a post, seems to have been taken down, but IIRC you just cut one of the wires on the 9pin harness on the carbed models...
Maybe someone will drop by with the right color wire info.
    • By camojay
    • By The Road Hound
      Hi,
      New to the forum.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
    • By Rick A
