This top is fabricated from 16 ga. steel. The sides are hemmed over and folded back on themselves (see pictures) for extra strength along the edges. The hemm makes a 1/8 inch thick frame around the outside of the top. In other words, this top will hold up to most tree branches hitting the top. [...]
View the full article
    • By D MAYNARD
    • By Jerrys500
      Thanks Jerr
    • By Jacob E freeman
    • By jimvmcgee
      I have a 2023 560 T Boss that I just noticed that back up lights not working, the camera come's on. The book tells you about tail light replacement, so was wondering if the lens is just there.
