I have a hisun 500 got from a auction and when turning a corner left or right it's a two hand job then when you left go snaps back.any help on what to look at would be appreciated.
Also blows blue smoke until she gets warm then it's ok
  • Alex changed the title to Hisun 500 very hard to turn
Steering issue:  My only guess is too much caster on the front axle that may be as simple as loose or incorrectly installed parts to a more complex bent frame.  Caster is what causes the steering system to return to straight forward.
Been there before.  Installed a power steering unit on one.  Boss reached thru the steering wheel and about broke his arm on turn on.  I opened the unit and scoped the bias circuit....OEM circuit board insertion  build error.  Replacement had same problem.  Info turned over to HiSun.  Given a unit by Massimo off of a working SXS and customer happy.  That was 4 years ago.  Should be a non problem with a new Power steering controller.
    • By CapnWalleye
    • By CapnWalleye
    • By Bobbers
