I have a 2014 landmaster S/S 4x4 model 653 4x4 with a 22 hp robins engine. I've been having problems with the govenor reving after it running a short distance. I cleaned the carb and discovered the fuel membrane has a slight pin hole (P/N 210-253). Can not seem to locate a replacement. Any suggestions? It appears this carburetor is no longer supported.
On 4/21/2024 at 8:23 PM, Clyde says said:
280-62358-08.
Clyde, are you aware that number is for a propane carb. Are you trying to run it on gas? That carb is available for around 300.-00. If you were noty aware that it was propane powered, I would be trying to get a refundGood luckYou may be able to switch it to gas but thats not my forte. Oh, I saw the part available on partstree and a coupla other sites (ebay)
Thanks for the info. I did locate the part on partstree and it was very expensive $291.00 plus tax and shipping total $325. The part wasn't much bigger than a quarter. I'll try and include a Pic. Anyway I installed it and the UTV runs well. Yes it is gas not propane. I switched to non-ethonal gas.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By mark walkom
    • By tskm
      Tom
    • By TPlummer
    • By Chucky 1
