This 2007 YAMAHA RHINO 450 4X4 "CAMO" EDITION - Asking price: $2800 is in excellent cosmetic and working condition. RUNS GREAT, LOOKS EVEN BETTER, HAS SIDE DOORS, GREAT COLOR COMBINATION. Very clean. Mint condition with no scratches. It currently has 40 hours and 344 miles. I'm the original owner. It has been well taken care of and garaged kept. For more information and photos e-mail me at [email protected]
    • By Brett
    • By A P
    • By mark walkom
    • By shawn b
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
