any one have these?
By hisun junk
As I tried to do a conversion with the Yamaha 660 motor, I realized the 660 was never fuel injected so it would not work for the fuel injected hisun motor swap. But the good thing is the hisun 750 motor is a clone of the 660 Yamaha but with the components for the fuel injection (cam/crank position sensor). So that left me with a new rebuilt Yamaha 660 and still a broke 750 hisun motor. I took apart 750 think the timing chain had broke from all that I've heard about these motors. The chain was not broke, but just off cam and crank gears! The chain tensioner was at fault! I've ordered Yamaha 660 replacement parts, chain, two exhaust valves (which got bent when chain came off while motor was spinning) and seals. The piston has 2 little nicks where it had hit valves but no damage otherwise. The head is being redone at the machine shop and I'll be putting it back together in the next couple of weeks. Also I finally tracked down a Service Manual with all the info on the 550/750 Challenger.
By KimAC
I need a pair of front shocks for a Landpride Treker 4200NT, from 2005? Does anyone know of a good salvage yard - or another source?
-Kim
By Gorj
I am having an erratic issue. Sometimes the solenoid/relay does not activate when switching on the power. Thus the electric motor does not work. You can hear the solenoid activate because it is right under the seat in the middle. The solenoid/relay connects the batteries to the electric motor circuit. When it fails at making the connection I get a 54C3 code on the display.
By Jamesjoh
I have been looking to outfit my new Polaris xp 1000 but have been finding prices all over the range for the same item. So I thought it would be good idea if we could all share here where you are finding the best prices and service rzr xp1000 accessories whether it be a local motorsport store or online.
By NicholasNWM09
Hello Everyone,
COOL NEW Product Alert!
A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system!
Go check them out!
Check out the websites : https://newwiremarine.com/ and https://rockerswitchpros.com
