Welcome!
Just a introduction to the offshore brand machines.
They tend to be underpowered and high geared for heavy loads or work.
Be sure to use low range when working.
Also i suggest putting your cooling fan on a direct ignition relay, bypass temp sensor, quad is on fan is on for work. Or you can put fan on a switch, turn on in low range, but you can accidentally forget.
These tips will help prevent overloading or overheating the engine
Cheers from Canada!
    • By Mike Jenkins
    • By HighSon
    • By GunnersTacklebox
