    • By BMurph
    • By BMurph
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
    • By Vanny
      I purchased a Hisun 750 Sector to use for my oilfield business. It quit running after only 12 days.  I was told by the very rude people at Hisun that apparently I wasn’t supposed to be driving it in the mud and that I also put to many miles on it.. so in-turn they will not fix it under warranty. Also, if the salesman tells you they are cheap to fix don’t believe it.  They want half as much as what I paid for it to fix it. My advice is be aware that these UTV’s are made for minimal use and not backed by the dealership or the manufacturer. Also it was thrown in my face by the warranty manager that since it was used for business the warranty is shortened to 90 days.   I’m not sure what the difference is since it’s not covered under warranty even after only 12 days.
    • By Rick McGill
      I thought the problem was electrical but I just found this in the oil filler tube. Does anyone recognize the part? I know I'll have to tear down the whole engine, and maybe I'll find the rest of it in there. Something beg enough to seize up the engine. That was the problem I was trying to diagnose.... 'Cause it's locked up.
      Rick
