Powersteering Trooper Renegade Vipers
By Greg Kilgore
By rev6engines
Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
Call or Text:
801) 489-8697
Email at:
[email protected]
Happy riding!!! 🤘
By PossumTruck
Greetings,
I have a client that wants me to install a heater of some sort to aid in cold weather starting (she uses it at her business, has had issues starting the last few days in sub-zero). I would prefer a coolant heater to a pan heater (silicone pad), but I cant for the life of me find the diameter of the coolant hoses. Heck, I'm not even sure if it would work as well in this application given how long the hose is compared to tractors and trucks I have installed them in.
Any advice you could give me would be GREATLY appreciated.
