Most atv utv i recommend 10w40 oil, period, but make sure it is JASCO MA2 for wet clutches, motorcycle oil.
U can use regular oil but it will burn easy cause of wet clutch and glaze the clutch, causing slippage.
Welcome and cheers from the North
    • By hisun junk
    • By JSwearer
    • By Justine
    • By Jacob E freeman
    • By A P
