2015 kymco 450i clutch noise and will not go
By diamondjfarm
Thanks.
By 4x4friend
I have a 2012 Hisun ut400 that I just bought. I was told it just needed a belt, but nope, all three clutches were shot. So I went online and found a couple videos on replacing the clutches. They stated that the wet clutch and primary clutch should turn easily counterclockwise and harder clockwise because it's turning the engine over. So that is what I'm getting when the wet clutch housing bolts are loose, when I tighten them the shaft now turns very hard counterclockwise. Anyone have any ideas as to the problem?
By Buck
My father-in-law has a Hisun 750. It has started to not change gears while running. He can turn it off, change gears, then restart and it will change. I thought it might have something to do with the brake but can’t find any info. Thanks in advance for any info.
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By Stan Morton
My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850. If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance. Kind Regards, ~ Stan
