I have 2020 Tracker 800SX LE that I bought new in 2020.  Yesterday i noticed two cracks in the bed in the corners at the tailgate end.  They go all the way through the bed.  I use it around the property moving firewood, dirt and stuff.  Don't know how they could occur.  Has anyone else had this problem?  Is there a fix?  Help!!!
  • 4 weeks later...
Heating and cooling of the plastic is probably the culprit.
The expansion and contraction of the plastic while being held tightly with mounting screws, in my opinion will make this happen.
I purchase a 2022 a couple months ago, New and it had the same issue.  Tracker warrantied the bed as well as two cracked panels where the passengers step into the back seats.
    • By Paul in Wisconsin
    • By Gary Odom
    • By Karlibob
    • By Xov
