SPOT Shared Page
This is a Spot Report, each spot is 10 minutes apart, Started the Ride out with Lenny, on the first day, the next two were just me and the wife. Had good ride, but got a little cold and the wind was up that weekend. Snowed back home in Pleasant Grove, Ut. while I was gone. Sorry, no photos, If your interested in that area and want the .gpx files to load onto google earth, ask for them.
Kinarfi
    • By Browner010
    • By jimvmcgee
      I have a 2023 560 T Boss that I just noticed that back up lights not working, the camera come's on. The book tells you about tail light replacement, so was wondering if the lens is just there.
