MOTORSPORT FIELD EVENT HANDBOOK
HOW TO CONDUCT A SUCCESSFUL ATV/UTV/MC FIELD/RODEO EVENT
If you’ve been considering promoting a motor sport field event, this handbook will save you countless hours and get you started toward success. It will take you from the earliest planning stage to the final steps on the field. In it you’ll find eleven sample events along with what’s needed to make them happen.
It covers: Event Considerations
What, where, when, how?
Event Logistics
What materials are needed?
Staffing Considerations
Who does what?
Who’s in charge?
How many people do you need?
The Paperwork
Signup sheets
Score sheets
Information to be posted
Waivers
The material is loosely bound so copies may be made using the forms as is. A CD is included so you may modify the paperwork to fit your needs.
Years of experience are contained in this copyrighted material. It is available for $49.95. If you would like a training session at your location I am available to meet with your group. The only fee in addition to the package cost will be my expense.
Richard Peck
520-885-6274
© 2007 Richard Peck
    • By hisun junk
      As I tried to do a conversion with the Yamaha 660 motor, I realized the 660 was never fuel injected so it would not work for the fuel injected hisun motor swap. But the good thing is the hisun 750 motor is a clone of the 660 Yamaha but with the components for the fuel injection (cam/crank position sensor). So that left me with a new rebuilt Yamaha 660 and still a broke 750 hisun motor. I took apart 750 think the timing chain had broke from all that I've heard about these motors. The chain was not broke, but just off cam and crank gears! The chain tensioner was at fault!  I've ordered Yamaha 660 replacement parts, chain, two exhaust valves (which got bent when chain came off while motor was spinning) and seals. The piston has 2 little nicks where it had hit valves but no damage otherwise. The head is being redone at the machine shop and I'll be putting it back together in the next couple of weeks. Also I finally tracked down a Service Manual with all the info on the 550/750 Challenger.
    • By REDfletching
      Spent today at a Honda dealership looking at their 520 side by side, then on the way home past our Lowes noticed they had several new UTVs on site, so we U-turned and ducked in there. We were impressed that all that came for $9,999 metal whole length skid plate, nice sized bed, roof, windshield, side mirrors, winch, upgrade looking tires… all of which would have added thousands of dollars to an already expensive Honda 520. Now Honda does have a great reputation from my trusted UTV experienced buddy, so it has that going for it.
    • By BernieG
      I could really use some help identifying some disconnected components on a Yard Sport YS400. The first part is this pipe, which comes out of the exhaust port area or the cylinder. It looks like it had a piece of rubber hose on it, but the hose is gone, and I have no idea what it was previously connected to.
      The second item is this vacuum valve looking thing.  Again only one line is still attached.  What is it's function and what other lines should be connected to it?
      The last thing is this hose, which exits the side top of the fuel tank (not the fuel line hose) but is not connected to anything
      Any help the community could provide would be greatly appreciated.  This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
    • By Gorj
      I am having an erratic issue.  Sometimes the solenoid/relay does not activate when switching on the power.  Thus the electric motor does not work. You can hear the solenoid activate because it is right under the seat in the middle. The solenoid/relay connects the batteries to the electric motor circuit. When it fails at making the connection I get a 54C3 code on the display.
    • By great8redsfan
      Okay folks. I have a low power issue. Been like this for a few years. Place I work at bought 3 and all have lost most of the pulling power.  They gave them away after local shop worked on one for 3 months and it had great power for about 1 month and then crap. They replaced throttle body, fuel injector, spark plug and IAC motor. Seat belt switches have wires cut and left open so no seat belt warning light anymore. It revs to 6k rpm in neutral but when put in gear and take off in low it just doesn’t seem to want to go anymore. Running 93 octane fuel with Stabil.  Any ideas greatly appreciated. I dont have a scan tool but no codes on dash. If held to floor it pops a little and runs almost 5K rpm but if I let off pedal about an inch it smoothed out and revs up to 6k rpm.
