T-minus 1 hour and 20 minutes till launch, loaded up and ready to hit the road.. See you guys tomorrow for those of you headed there!
lookin gooooood.sure you wanna get her dirty???(LOL)
Have fun.
Tires and wheels look great! What size are they???
Great looking ride Snowman....when you wired in your piaa's up front....did you bypass the on/off switch that comes with them? I'm in the middle of converting my stock headlamps with the piaa's and I'm not too savy at hooking up electrical equipment. I thought I could just wire these piaa lights directly to the leads coming off of the old headlamps switch. Any information to steer me in the right direction would be appreciated.
Randy
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Michigan sport.
      I'm sure many of you are aware of Michigan's emergency brake requirement.  I'm wondering if anyone has a good solution.
      Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to  the Maverick sport rear mounting bracket?
    • By Texjpr
      2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass  switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
    • By Hugh
      Hugh
    • By Farid
      Hey there,
      I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
      Also, if you’ve got any other parts for this model, I’d love to hear about them!
      Thanks a lot!
