Hisun 800 shuts down
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
Highly recommend you get the setup described in this post for further troubleshooting:
Is it overheating? Does the fan come on? Any other symptoms? Any codes on the display?
The scanner info above will allow you to see what all the ECU sensors are seeing and you can troubleshoot what could be a sensor issue, as well as codes and pending codes (which won't show on the display)
    • By John M in Louisiana
      Thanks in advance!
    • By fishhouse3
      This machine is ready to go and needs nothing - just hop in and hit the trails!  I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
    • By A P
    • By John Gubancsik
      I started my UT400 but forgot to buckel my seat belt.  It bogged down and then died.  Only way I could restart it was to press the gas pedal and if I let up on it, it stalls.  Any suggestions?  Thanks.
