What motor oil and weight to use?
By Cory J
By hisun junk
By Kingfish
By Charles Hamilton
**Disclaimer: Yes, I know Polaris and Kawasaki are SOOO much more better, reliable, retain their value, not made in China, etc. I need a UTV and don't have the money or financing for one of those units, so let's keep this discussion productive please**
Hi all, learning about my new T-Boss 760 from TSC, and am trying to find the actual dip stick to check the oil, funnily enough.
Does anyone have a picture of it or something? It's crazy that I can't find it...yet here I am.
Also - any advice on oil? Manual says 15W/40 "SJ" but I'm told the SJ spec doesn't exist anymore.
Gentleman at TSC said to use any 15W/40, but I'm very nervous about causing an issue this early on by using the wrong oil.
Anyone have advice?
