Slow Starting...High Compression
By ned
I have a Kubota RTV -X900 that I recently got from someone that is in good condition. I'm trying to determine what year it is all to no avail. I have the 16 digit product identification number and have gone on line to multiple sites with no luck. The number is A5KB2FDBCFG024444 . I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit. Thanks in advance.
By CRV
By Roadstar515
Regards, Rick
By SayHiToRambo
08 trooper 1100
thanks!
