Len, did you end up with any of the diffs from the auction? Thinking the lower gear sets? Also VW used a gear reduction unit on the Bus transaxle, Maybe?
Side note: Will weld the new diff braces tomorrow. All cut and made but too sore from working on the house! Getting ready for the monsoons is more important!
rocmoc n AZ/Baja
Guest Lenny
rocmoc n AZ/Baja
No I didn't. Stopped at $400. They sold for $700-$800 if I remember correctly. Figured I could buy the lower gears for less.
    • By Unhappy Kioti K9 Owner
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
