Trooper Snorkel
Howdy new member here . My hobby's Rabbit dogs , gamefowl . I'm retired from my real job but I stay busy with the hounds and gamefowl . So to help around the farm I ran across an old 2007 CC Big Country 4x2 to haul feed , water , sprayer and my sorry a$$ .It is in pretty good shape , 781 hrs. good plastic , tires, ect. . But as anything outside and 18 years old it needs seats ! The thing I have found wrong mechically the Diff. Lock Acturtor is broken where it mounts to the bracket ( partly why Im here ) . Hoping someone here can help ! Just my wish list but Id like to find a roll cage and a composit/plastic top for it Im thinking I'll need a donor to salvage these things from ( again partly why Im here ) .Is there another brand that uses this same actuator? If anyone reeds this and has or knows of any of threse parts PLEASE HOLLER !!
By Robbie Wyre
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Buck
My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts. I thought it might be a brake problem but he thought clutch. He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing. Any ideas would be useful because he really can’t afford throwing money at it.
