It's me, Ernie again. I searched high and low for a topic on this before I posted this.
I have no more clutch adjustment by the clutch fork, it's grinding gears.
I unbolted the clutch fork, moved it one notch closer to the hydraulic for adjustment.
It caused too much throw and is now riding the clutch and RPMS are going nuts.
I put it back the way it was and am going to adjust the upper part.
I just cut the firewall to get clearance to access it from the front.
There is no more adjustment from the stock position and is grinding gears.
Does anyone have any suggestions about adjusting? Any and all ideas will be most helpful.
Ernie
New Clutch! Hate to say it but sounds like the fix!
rocmoc n AZ/Baja
Thanks for confirming my suspisions.
Ernie
Be sure you mark all the sensors & electrical plugs WELL when you pull the engine. Best tip I can give ya! Read my engine pull & clutch post of last year for tip with throw-out bearing.
rocmoc n AZ/Baja
rocmoc n AZ/Baja
I found that post while I was looking for a post re adjustments. Thanks for the help!
Ernie
    • By Bryan g
    • By Buck
       up.
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
