AZ off-road (OHV) sticker in CA
By bfisherman11
In 2016 I bought a midsized Ranger ETX. I don't recall exactly my out the door price but it was probably less than 8k. I've used it as a work machine around our home and 38acres. It's always run great and requires little maintenance. Still running strong.
So, for no reason I checked out a local dealer. I like the midsized UTVs so that's where I started. I was shocked the cheapest 570 I saw was a shade under 18k. I know an ETX Ranger was a budget SxS but wow, that's a 10k jump. When I was shopping back in '16 I think a 570 was about 1k more than my ETX.
Well I guess I will be running this ETX till it breaks.
Anyhow, I'm a big fan of the Rangers. When the time comes I'll be back but I had no idea. I haven't posted in a while. The ETX must not have sold a lot because you don't see many things posted. Hope other ETX owners had the same reliability I have had. I'm guessing if a cheap Ranger series like mine has been reliable then the guys with bigger ones are enjoying those as well.
So, great machines, probably priced per the market but I had no idea. Ha
By TPlummer
By Kingfish
