By CSM_Retired
By FTG-05
By Smittay
I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
By Matthew Smith
2013 Bennche Bighorn 700 EFI
