For the life of me I cannot find the directions on how to change the display to the standard for the USA - MPH. Not sure why Tractor Supply didn't do it before I bought it but it is what it is. Does anyone have the instructions to do this. I have the 2023 T Boss 550 just to be clear.
THe UTV has Massimo T Boss 550 labeled on it. I don't see Coleman anywhere but they could be made by the same folks. The display is digital and only shows metric values for speed and odometer. I found some instructions before that were somewhat bizarre. Now that I am ready to try it I can't find them. It has been very difficult to get it nailed down.
  • 4 months later...
Not sure if you ever figured this out, but I just bought a T-Boss 760 and had the same issue. On the console above the steering wheel, you have a button A (left side) and button B (right side). Button A toggles through the odometer, hours, and trip miles. Per the manual, button B is supposed to change the display from KM to MPH but nothing happens when I press it. Then I found a Facebook post with the correct instructions. Using button A make the display show the odometer, then you just press button B and it toggles between KM and MPH. If you have the console showing anything other than the odometer, then button B does nothing. It worked for me, hope it helps someone down the road. Very annoying its not in the instructions, but also wasn't surprised.
    • By Gorj
    • By Smittay
      I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
    • By SteveS
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
