Coleman ut400 add lower gear
Go to solution Solved by aefron88,
  • Alex changed the title to Coleman ut400 add lower gear
30 minutes ago, aefron88 said:
I don't believe it would fit. Any particular reason why? Are you just towing/plowing at low speeds?
Live in the mountains and need lower gear to climb at lower speeds and to hold back coming down.
  • Solution
If you have a powersports shop that works on clutches you could get them to put heavier rollers that will keep the cvt in lower "gearing" at the expense of top speed.
    • By Marie
      Thanks in advance.
