I've been trying to get ahold of Lenny for 3 wks. PM's not working, and no responce w/ e-mail. I need to see about diff upgrade kits. Thanks
PM's don't see to be working for me at all..... anybody else having this problem???? ADMIN?????
I have been speaking to admin and he says there is no problem. I found that I had too many messages stored and had to delete some. Flatbed did also & I believe that is Lenny's problem also. Hopefully he will respond to you. If not soon you should edit your personal info out. If he does, edit your personal info out.
rocmoc n AZ/Baja
Guest Lenny
I've been trying to get ahold of Lenny for 3 wks. PM's not working, and no responce w/ e-mail. Please call me @ 775- 753-8223 9- 6:30 T-F or e-mail me at [email protected] I need to see about diff upgrade kits. Thanks
I'll check my messages for too many and delete some. I'll also give you a call tomorrow.
    • By A P
    • By clint501
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
