Differential upgrade kits to be available
Guest Lenny
Guest Lenny
I have ordered everything I need for a new run of differential kits for the Trooper. I'm making a limited number of them so if your interested, let me know. They will be $135 per kit includint shipping to the continental USA and Canada. Two kits will be needed for both the front and rear differentials. This kit solves a lot of serious problems with the stock differential including the ring gear bolt shearing problem, the spider gear pin coming out problem, pinion gear to ring gear alignment problem and general undesirable slop through out the differential internal mating parts and shafts. Forum members get a $10 discount per kit if purchased from me directly and not through Ebay. Each kit comes with very clear and well detailed instructions with lots of instructional pictures.
We should be able to start shipping out Differential upgrade kits the first part of next week. Unless someone post a question or something that requires a response by me, I will not be posting under this differential upgrade topic again. I don't feel it's appropriate to use the forum as a sales billboard and only mentioned the kits here because so many of the forum members have asked about the kits. You can still order them as a forum member and get the $10 discount per kit provided you order directly from me and not through Ebay. This and other items I offer are on Ebay. Thanks to everyone.
When you get them on ebay, I suggest you add one more post with a ebay link, I think it would be appropriate, since you are making the for forum members.
Kinarfi
Kinarfi
Here is an E-bay link to the Differential Upgrade Kits.
http://cgi.ebay.com/ebaymotors/JOYNER-Differential-Upgrade-Kit-Trooper-Renegade-_W0QQcmdZViewItemQQitemZ260655753348QQptZOtherQ5fVehicleQ5fParts
    • By Xov
    • By Travis M
      Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
      I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
      I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
    • By joynersfuntillitbreaks
