possible substitute parts for Joyners
Guest Lenny
Ran across this information on another forum. Thought it could be quite valuable to owners.
Maybe this will help all the Joyner owners out, after hours and hours of research I found that the 2007 and older Chery engines are a clone of the ford's Britian CVH (escort) motor such as the 1.1, 1.3, 1.6 and 2.0. The great thing is that even though it was a clone of the Britian Ford CVH motor, they used 90% of the same parts as Ford U.S. CVH motor. The trannys are a VW model gear boxes with Ford bell housing. Least that is what mine is. Like the 650, 800 & 1100 are from a 1.1 to 1.3L VW golf. I have the 2006 1600 Joyner and my tranny is from a 97 VW Jetta. Now I'm not saying everything will bolt right up on the 650, 800 and 1100's you'd have to check that out yourself. But I know a friend that has a 800 Roketa and replaced transmission parts with a 1.3L VW golf. Another friend with a 2007 Joyner 1100 used gears and several other parts from a 1.3L Golf tranny. I have a 97 Jetta tranny that matches perfect to my 1600. I'm currently running a VW Jetta starter on my 1600. I bought several ford escort parts as replacement parts that fit perfect.
Just do some research or pull photos of the VW 1.3L tranny and you can compare what it looks like to what you have. Do the same on the engines. Google photo of the 1.1 or 1.3 and see if they don't look real close to what you have.
pghruby, where did you get this info from? The 1st time I fired up my Trooper, I thought it sounded like an Escort Rally car with a straight though exhaust. I have owned 1.1s, a 1.3 and a 1.6 Pommy (English))Escort cars and vans & raced a 2L so know a fair bit about them and the sound is bang on. Man if your right I'll be as happy as Tiger Woods wife just as she gets half of everything. Over here there are all kinds of mods for these engines and if I can tap into that she will be all smiles. These engines are still running strong after 42 years so I guess they copied a good one. These were fast cars that didn't break down. The T2s don't rev that high so if they are the same all be it a clone, there must be more in the engine somewhere. Cheers Mike.
I was always under the impression that these engines were Isuzu based. It gets quite convoluted since Suzuki and GM had joint ventures (which explains the Opel diagnostic protocols). Even VW and Subaru has joint ventures with Suzuki. The Geo Metro used the G10 engine that most people feel is the basis of the Chery engines.
Thanks pghruby, at least that clears that up. Looks like you can get a stock supercharger for them as stated here........ http://en.wikipedia.org/wiki/Mitsubishi_Minicab but they don't mention what engine size its for.
Cheers Mike.
So how do I get more torque? I raced SpecRacer Ford for years which was 1.6 Lt. Escort powered. We in the group never thought the thing had power and was always asking SCCA when they were going to replace the Escort with something that had power and didn't sound like a tractor. I know my clutch was larger on my SpecRacer and the injectors were different.
rocmoc n AZ/Baja/NM
Guest Lenny
rocmoc n AZ/Baja/NM
One thing you can do is match both the intake and exhaust ports. They mismatch as much as 3/16". When you match the ports going into the head, open up the ports giong to the valves themselves. Stay consious of head thickness where you cut. Flipping your intake to the top side should give a bit of benifit and eliminate the corragated hose on the intake. Also with it flipped, you can you can easily get at the throttle body and even the starter. I did read that the engine design is good to about 6000 rpms. If this is exceeded, it was sujested that different rods and pistons along with a steel crank be installed. Right =now we just need to keep scouring the internet until we actually find the the car model with the comparable engine that has exchanageable parts. If that ingine is popular, we should then be lead to available upgrade mods. Searched the internet for about 3 hours the other day and saw some things that looked close. the following is the engine we have I beleive with slightly different additions.
http://www.cheryacteco.com/en/article_detail.jsp?article_id=11763537670001&cmColumnID=11762828710001&parentColumnID=11690974370001
Hey Lenny, that's me talking to pghruby on Joyner Forum. I got a little excited and typed a reply before really thinking things through. The 1.1, 1.3, 1.6 and the 2L engines back then are generations away from the Chery 1.1, 1.6 and 2L Joyner have been using in recent years. What worked back then, might not work now. The first generation engines I was referring to where carbureted OHV engines, we have DOHC injected engines now. If Chery have based their engines on the original Ford engines(this is where I jumped to the wrong conclusion), it sure was a good one to copy, but they have updated all the components to such a stage where they would not have too much in common anymore.
pghruby was referring to the Ford U.S. CVH motor from the 80s & 90s, not the British OHV motor from the 60s & 70s(that I was) and a VW Jetta transmission so just take notice of his statement as mine is non-relevant.
rocmoc, there were 1.6 ford engines and 1.6 Ford engines back in the day and my memory of the Ford Escort 1.6 engine is the opposite of yours. It could be that you guys in the States had quicker engines of the same h.p that we didn't have, or us in N.Z, Australia and the UK had the know how to get the best out of these engines, I don't know. Did yours sound like this
Mate, if that sounds like your tractor, at least it's the best sounding Tractor around.
While I was playing around on YouTube I found this clip which I know most of you will enjoy
Make sure you watch part 2.
Cheers Mike.
Hello Mike,
First video; Sound is close but the video sounds better, more responsive.
Second video; Not the same engine. The engine is almost a mirror image. Our Escort engines were supplied by Ford USA but were actually the HPO Mexican Engine.
rocmoc n AZ/Baja/NM
Double click on the YouTube screen to watch it from YouTube itself, then pause the video screen on UTV Board so you don't have two running together. In the format above, it hasn't got all the info on it. rocmoc, you will then see that I did cheat a bit, because in the 1st video it states, 'the greatest sound ever in a Mk1', so I got the best example to be fair.
In the 2nd video, it is actually a breakdown of a DOHC 4 cylinder engine, or our Chery 1.1 engine.
Cheers Mike.
Guest Lenny
Cheers Mike.
The engine in the second video is more like the redesigned version of our engine. It used two cam driver pulleys rather then one like ours. Everything I could find with DOHC had this camshaft setup. The 1100cc are hard to find anymore in more current cars it seams but from 1.3 on up now use the DOHC setup with seperate driver pullys. Not sure why they made this change unless it was to go to rocker lifters rather then the cam lobes pushing directly on over the valves. Seems like our setup would be more efficient but then maybe they also changed the angle of the valves and it required the switch. Don't know, just guessing.
  • 13 years later...
Hey guys new here got a 2013 joyner sand viper 1100. Only issues I've had is the clutch cable and starter. I recently purchased a starter for the Metro 1.1 and the top bolt lines up but the lower one is just a hair off so I couldn't use it. And the one for the Metro was a gear reduction and the other one from the joiner was a direct drive. I'm just trying to save a little money on the starter any suggestions to be much appreciated
    • By Gerald Dillman
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
