Put a new carb on the 500 to replace the leaking OE one.  Machine idles fine and mid and top end runs great.  It tends to have a hesitation right from the start - bottom end.   Thinking it may be the air/fuel screw??  I didn't do anything with the carb out of the box and is it direct replacement for my machine.  Of interest is the manual choke doesn't seem to work very good now.... wonder is it getting too much air?
Any help appreciated!
Just going to follow-up on this one.  I turned the fuel/air screw out 1/4 a turn (counterclockwise) and the hesitation is all but gone.  Might do another 1/4 turn rid it completely.  She needed more fuel.
It sounds to me that the acceleration nozzle (or pump) needs to be adjusted.
The thing runs great at idle and mid and top range. It only needs more fuel when you open the throttle.
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By SpaceGhost
    • By D MAYNARD
