Start relay
By Jon V
By Rick A
By Goat Quilter
We pout new belts cleaned engine and carburetor plugs you name it. Drove down road no problem came back uphill no power won’t go . What’s the issue?
could it be clutch?
By Goat Quilter
New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
Could it be clutch issue??
so frustrating this thing has been in shop more than used on our farm.
By GWS
