Changed radiator to larger one
By D MAYNARD
By Jacob E freeman
By PossumTruck
Greetings,
I have a client that wants me to install a heater of some sort to aid in cold weather starting (she uses it at her business, has had issues starting the last few days in sub-zero). I would prefer a coolant heater to a pan heater (silicone pad), but I cant for the life of me find the diameter of the coolant hoses. Heck, I'm not even sure if it would work as well in this application given how long the hose is compared to tractors and trucks I have installed them in.
Any advice you could give me would be GREATLY appreciated.
By William P
After a short while of engine running the temp light comes on and the water in the radiator water is boiling., water level is ok pryer to starting engine. This is consistent. Coleman 400 bout 3yrs old
