They are preformed hoses for a specific application. If you go out to your car and look in the engine compartment, you will see the same thing between your radiator & engine. They could be for anything. Can't tell with a part number and if they are gone you/someone will just have to trail & error to use.
rocmoc n AZ/Baja
  • 4 months later...
    • By Wolfpaak
      Kenny
    • By Marie
