Pro-One has just added these exceptionally hot and handy GRAB HANDLES to their extensive line of custom accessories for the Yamaha Rhino. Each handle is precision machined from solid billet aluminum and polished to a mirror finish. Pro-One GRAB HANDLES are offered in either 6†or 12†lengths and you have your choice of either [...]
View the full article
    • By mark walkom
    • By hetovi
      Hello everyone.
      I recently bought a Can-Am Ryker and I'm looking to customize it with some accessories. I’ve seen a lot of options out there but wanted to get some recommendations from fellow riders.
      What are the must-have accessories for comfort, style, or performance?
      Specifically, I'm considering a windshield and better footpegs—are these worth the investment?
      Also, any thoughts on storage solutions like saddlebags or rear cases?
      Would love to hear your personal experiences with any mods you’ve done.
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
