Installed king shocks what a ride. 2.0 front 2.5 rear.
pictures & model numbers, please and did you change springs in the front end? If so, what did you use?
Kinarfi
Kinarfi
Call king shocks and ask for Mike Eads, They have all the specks for Joyner T2,T4 and will build you shocks around $2300. so smooth. My brother in law just orderd his. (714) 530 8701
    • By KimAC
      -Kim
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By tskm
      Tom
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
