ANOTHER SPRING QUESTION
Gumball
I'm playing with some KONI 30 series shocks. I intend to put them on the front of the T2. I was hoping I could use the stock springs but that was not to be. To fit over the sleeves the springs need to be 2 1/2" ID. Naturally the Joyner springs are slightly less than that. Forgive me for asking this again but, can anyone tell me what the front spring rate is in pounds.
Thank you,
Gumball
      A while back I was looking at an auction UTV plow and the mounting of it.  Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV.   I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn.   I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place.   The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
      Anyone ever try this for a front mount?   It would be close to  this one that is for sale on the net.  It is supposed to fit a KFI plow mount.
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
    • By Bryan83c
      Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with.    Something autozone might carry  and what cars are these chery motors most compatibility with
    • By BernieG
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
