I had my snorkel coming up between the seats and the filter was about the same height as my ears, it was too noisy that way so I moved it up above the over head cover. It sounds great now and this is probably my last change for the snorkel system, the only change I can see making is changing the hose to what's called material handling tubing, smooth on the inside and clear with a spiral band on the outside.
Kinarfi
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Jacob E freeman
    • By Kingfish
    • By Woody77
