UTVBOARD will be down from 7pm EST today and most likely overnight through Friday morning, while we change our server settings. We should be back up within 24 hours or sooner, depending on where you are and how fast the internet recognizes our ip address changes.
We apologize for the inconvenience.
    • By Gorj
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Roadstar515
      Regards, Rick
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
