With cage mod comes a different way to cover the engine. Need input!
Choices are;
No Cover. Build framework to hold ice chest & spare tire.
Expanded metal, the stuff with diamond shaped holes & framework to hold ice chest & spare tire.
Solid alum cover with framework for ice chest & spare tire.
I am favoring one of the first two so heat is swept away. Weight is about the same between the expanded metal & alum, the difference is how the air flows thu the engine compartment. What do you think?
rocmoc n AZ/Baja
Choices are;
rocmoc n AZ/Baja
I would at least use perforated(flat sheet with round holes)on the bottom where your cooler sets.Will still get your air flow but it will be nice and flat.
Choices are;
rocmoc n AZ/Baja
I would go with flatened expanded aluminum or perforated aluminum. Expanded aluminum is available and you can make your own perforated sheet. Use an electricians step drill, used for drilling holes in electrical boxes. They work great on sheet and the one I have drills all the way up to 1" dia. very easy. As you can guess, a drill bit for larger holes, I'm thinking 3/4" or larger, doesn't work to well on sheet unles you use a drill press. Cant get a big sheet into a drill press. Check ebay for expanded aluminum, lots available. YOu wuld probably have enough space to put a good 3000cfm radiator fan under it to suck air from the cover down into the engine space. This would be cleaner air too.
I have ruled out the on cover option because I would not be able to haul stuff found on the trail back to camp.
Expanded metal, of some sort, will be the option.
rocmoc n AZ/Baja
I thought I told you that stopping here and there to pick up aluminum cans is not the road to riches.
    • By GaryC
    • By klm
      So here is my dilemma, I bought a 2014 Massimo MSU500 eleven years ago from TSC, its never been off the farm, had my share of ups and downs with it but never walked back to the house. I have bought a Kubota Sidewinder and it is a fine machine.Problem is I just dont need the Massimo and would like to sell it but the last thing want to do is sell it (cheap) to someone who doesn't realize what a POS a Massimo  can be and can't afford to maintain it.  I plan to put it of Craigslist with pictures and description, not sure how to warn potiential buyers without scaring them away.  I feel like it could be a great buy for the right person or a terrible buy for the wrong person.  I'm thinking $2500.
    • By boydog40
      thanks guys
