As per a request from
Kinarfi, maybe you could slplit out the talk here about computer diagnostics and put it in it's own thread. That way we may get more input and could resolve the problem for once and for all. Looks like we may be getting close.
I have copied several posts and copied them here, Hope I got it so it can be understood,
View Post Lenny, on 31 August 2010 - 08:06 AM, said:
I've had a cutout problem on my Trooper so have been checking the wires. I'll post that in another thread. In the mean time I found something that I didn't like with the computer. Since Farmington, my computer didn't have ground unless I ran a separate wire from the computer chassis to ground. Then everything worked OK. Yesterday I opened up the computer to see if I could find anything of a grounding problem. Didn't find anything except it had a bit of dust in it. The computer isn't sealed at all and water and dust can get to the inside. I suggest that everyone pull their computer and silicone all the way around the cover and plug receptacle. Mine did show the signs of a bit of water too having got to the inside at some point from washing it.
I have been checking my MAP/IAT (manifold air pressure / intake air temperatue) and I think it's still good, I applied 5VDC to it and the MAP output was 3.655 volts. I'm hoping someone knows if this about what I should expect, if I add to the air pressure using lung power, it would rise over 4.00 volt out and if I subtracted from the air pressure using lung power, it would fall to below 3.00 volts. The IAT output was 1.809 K ohms at about 84 F, in cold water, it rose to 3.46K ohms and in warm water, it fell to 1.060K ohms.
The information for testing is on page 99 of the T2-T4 owners manual. I also traced pin 70, blue wire, Mal-Function Indicating Lamp output wire and found that it dies at one of the plugs near the computer. I have brought it out and plan to hook a lamp (LED) to it tomorrow.
After reading Lenny's post, I opened my computer up and found some water traces and dust also, I have seen what water, copper traces and electrical energy, especially DC can do to printed circuits, disastrous, So I applied silicon all the way around the computer filling any openings that would allow moisture in. I have always had mine wrapped or inside a bag of some kind and I still got water inside. I highly recommend opening, inspecting, cleaning if needed and siliconing the outside of your computer, especially if you are not in a dry climate or wash it from time to time. I have some photos of what I saw, but the camera is in the garage and I'm tired. I'll add them tomorrow, good night.
Tried it again and this time it worked, but I had to floor it to get it to start, but at least it started, I've been trying to get it to start using the first part of the throttle, but when I pull it or coast it, I end up floor boarded so I should probably start just flooring it and see if that works. When I try to start with minimal throttle, I ofter notice the smell unburnt gas. I did get my malfunction light hooked up and once the engine is running, it goes out, tried unhooking a few sensors and the light came on.
Good work on the fault code light. Now if we can find a scanner that will read the computer for diagnostics we will be all set. There is not a plug in receptacle for the scanner but the terminals for it are on the computer and the schematic for the Trooper shows the plug and which pins the scanning leads from the computer go to, so we could get one hooked up. I'm thinking that a lot of standard scanners would work being that it is a Siemens or is it Bosch computer. I doubt that they set up different codes for all the different cars. A lot of the car computers look identical although they may have different call up tables telling them how to respond to various conditions, they probably all have the same code for same sensors not working. Anybody have any thoughts on this.
When I take my Yukon for for safety and emissions testing, the tech plugs in the vehicles computer and get all the info, I think he has just the one plug and I bet they are standardized. Ours should follow, I'll look around and call him.
kinarfi
Any one want to set up the Malfunction light? it's easy, I picked up the +12 volts off of the battery at the winch relay, put a 1 amp fuse inline with a 1000 ohm resistor and a red LED to the blue wire and duct taped it to the computer cover. Can't see it while driving, but that can be changed quite easily too.
Hi , I believe that Joyner system diagnostics are obd2 compliant,they should have standardized trouble codes . It would be pretty easy to wire up you can buy obd2 connector just need power,ground data line terminals added to the connector and use a generic code reader .With some research Iam sure we could find a laptop based program and cable lead to read actual data streams
If you haven't already downloaded the wiring diagram from here, http://www.utvboard.com/topic/392-parts-pieces-and-information-for-our-troopers-joyners/page__view__findpost__p__475 , you should. I has the pin out for the computer and the inputs and outputs for the computer, including the CARB or OBD2 out put information. It's under:
Manuals and Information
Checking on Ebay and other places, it looks like code readers are quite cheap.
http://cgi.ebay.com/ebaymotors/OBD-II-SCANNER-OBD2-2-SCAN-TOOL-CODE-READER-OBDII-ENHAN-_W0QQcmdZViewItemQQhashZitem5889a04b63QQitemZ380266105699QQptZMotorsQ5fAutomotiveQ5fTools
Now all we have to do is determine what protocol the Trooper uses.
SAE J1850 PWM
SAE J1850 VPW
ISO 9141-2
ISO 14230 (KWP2000)
or and most likely it's the newer protocol called CAN (Controller Area Network).
CAN was used in some cars starting in 2003, and is said to be the only protocol that will be used after 2007
WE only need one, yours! LOL! WE need to start having an annual Tech Session at your place. When do you want US ALL to show up.
rocmoc n AZ/Baja
Shoot, I can sleep 5 in my 5th wheel if one sleeps on the floor. Can throw a couple of cotts out by the waterfalls and the rest will have to sleep in my shop or garage but that works for me. Just head this way and we'll have a wild blowout party. Wow, retired and wild blowout on the same line, we may have to lighten up on the wild blowout part.
  • 1 year later...
If you are interested, there is an out put from the computer to tell you if there are any faults, You have to supply an indicator light with power and then tie that into the computer harness, I used an LED and a resistor to limit the current and picked up the power from the winch, handy, and then taped it to the computer cover with the LED showing, it's wire #70 and if you have downloaded the computer wiring schematic from part and pieces, it's in the lower right of the print,
Nice I am interested.. I think someone put a OBDII plug on mine if they didnt come with one.Mines an 09... SO they might have it pinned incorrectly then..My question..... DId they come equiped with a plug or not ?
Mine is an 09 and it did not come with a plug.
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By JimG
      Best way to reset the computer?  Can I just disconnect the battery for a few or do I need to do something else?
