Trooper computer outputs we can use
By Ed Michael
My older LM 650 is blowing fuel into the air cleaner. Any idea on what would cause this? It is the Suzuki motor. Not sure what model year it is.
Subaru SxS.mp4 -
By SayHiToRambo
08 trooper 1100
thanks!
By Alien10
By JimG
