Anyone know where I can locate a clutch cable for a 2008 Joyner Commando, not having any luck locating one. Sorry if this has been addressed but in a real need for one. Thanks for any help
I know there are various cables listed on ebay.Look in ebay motors,parts,ATV,and do a search for joyner.Many items pop up.Good luck
Yup, a lot of stuff from the Joyner auction went on to eBay. Plus there are shops that make cables. Ask around at bicycle & motorcycle shops where you live or Yellow Pages. Also Google for custom cables. Not that hard of a product to make.
rocmoc n AZ/Baja
If it's the same as Troopers, check into brake lines at your local parts store of if you have a place like House of Hose like I do. Post a photo and the length of what you need, I just ordered brake cable from JMC and got it with in a week. Something like 27 bucks + shipping.
Kinarfi
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By JOSEPH LAMAR
    • By Jacob E freeman
    • By Texjpr
