Applications for Funding Now Available Online at Yamaha-Motor.com/OHVAccess
Yamaha Motor Corp., U.S.A. is proud to announce the launch of its OHV Access Initiative, designed to support safe, responsible riding and sustainable, open riding areas. The purpose of this proactive, grassroots program is to enable Yamaha dealers and customers to fund deserving projects that support the [...]
View the full article
    • By hisun junk
      As I tried to do a conversion with the Yamaha 660 motor, I realized the 660 was never fuel injected so it would not work for the fuel injected hisun motor swap. But the good thing is the hisun 750 motor is a clone of the 660 Yamaha but with the components for the fuel injection (cam/crank position sensor). So that left me with a new rebuilt Yamaha 660 and still a broke 750 hisun motor. I took apart 750 think the timing chain had broke from all that I've heard about these motors. The chain was not broke, but just off cam and crank gears! The chain tensioner was at fault!  I've ordered Yamaha 660 replacement parts, chain, two exhaust valves (which got bent when chain came off while motor was spinning) and seals. The piston has 2 little nicks where it had hit valves but no damage otherwise. The head is being redone at the machine shop and I'll be putting it back together in the next couple of weeks. Also I finally tracked down a Service Manual with all the info on the 550/750 Challenger.
    • By Howard Elmore
      I have owned mine for a couple years now but newer took off road.  How well does it do trail riding m?
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Eagle Mountain Outfitters
      Our R&D team just finished the first unit and wanted to show you guys. Need more cargo space without losing the functionality of being able to fold down the seat to use the full bed? Eagle Mountain Outfitters, the maker of the original metal UTV roof, has designed a foldable rear cargo basket to meet your needs. Price is $625 + $30 shipping.  If you have any question's, please reach out to me at [email protected]
    • By Kingfish
