  • Newbie
While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head  The two switches are literally 6 inches apart.  Does anyone know what this third switch is used for?  If i can figure out how I will post pictures.
  • Newbie
  • Author
Finally got the pictures took.  See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at.  Any help would be appreciated.
One is for the overheat light, and one feeds the ECU coolant temp for fuel mapping adjustments. I believe the one on the head itself is the ECU one.
There's also a third one in the radiator that controlls the fan.
    • By Joseph Sills
    • By Flanman55
    • By Croppy38
    • By camojay
    • By weasel
