2011 Massimo HS500UTV-EFI third temp switch?
By weasel
By camojay
1400 miles on it
20240817_133539_1.mp4
By Brent4a
2022 Axis 700 overheating. We bled system several times, no luck yet. Weird thing is Radiator isn't getting hot and air coming into overflow jug. Doesnt seem like its moving water. Fan working fine, even wired it to turn on by switch. Only has 100 miles or so, just baffled. I am going to try bleeding more and see what happens. I did the head gasket test for fumes in the antifreeze, that was neg so far... Thanks
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By 4x4friend
I have a 2012 Hisun ut400 that I just bought. I was told it just needed a belt, but nope, all three clutches were shot. So I went online and found a couple videos on replacing the clutches. They stated that the wet clutch and primary clutch should turn easily counterclockwise and harder clockwise because it's turning the engine over. So that is what I'm getting when the wet clutch housing bolts are loose, when I tighten them the shaft now turns very hard counterclockwise. Anyone have any ideas as to the problem?
