post-703-074268100 1285035166_thumb.jpgpost-703-072939500 1285035142_thumb.jpg
Is there anyone out there who owns a BMX UTV 500cc? CFMOTO is the motor in the UTV. I'm very seriously intrested in buying one. Any feedback, or any information on this brand?
the website I found it on is http://www.bestpriceatv.com
If you click on UTV on the left hand side, you'll see "UTV" and this is where I've been looking.
Thank you.
Dawn
Hi Dawn,
Did you buy one of those BMX SXS's? I think the distributor is in Dallas, Tx. I'm going to see if I can drop by and look @ them and will let you know what I see.
Ride-on, Bobby007s
Thank you.
Dawn
Thank you.
Dawn
I think there is a pretty extensive discussion and report on "Mud bog" forums." Most seem to be pretty happy.
  On 9/25/2010 at 1:48 AM, Bobby007s said:
Hi Dawn,
Ride-on, Bobby007s
Bobby007s,
Yes, as matter in fact, I did purchas one just last Tuesday, (September 21st) I dont' have it yet, it is in order and should arrive this week. Yes, it is coming from 13401 Denton Dr. Dallas, TX. I got the 2-seater pink one. I was going to get the 4-seater, but decided on the 2 seater being in my state, they are trying out the Piolet program and testing the trails out here to see if the UTV's will be able to stay on the ATV trails. I wasn't sure in the long run (2 years) if the 4-seaters would still be a go. They are now, but not sure in 2 years. However.........there's a good chance the 4-seaters will still be good to go on the trails. I got the Pink 2 seater. Just like the 4-seater, but its a 2 seater. I'm excited! I'm hoping I made a good choice.
I look forward to your response. Thank you. :rolleyes:
Dawn
Thank you.
Dawn
Thank you for the feedback. I'll check out the "Mud Bog" Forums" thank you again!!
Dawn :D
Thank you for your replies. Bobby, let me know what you find out in the Dallas, TX warehouse where they build the UTV's
Thanks a bunch!!
John1139,
thank you for your comment!
Dawn :P
  • 12 years later...
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
      Anyone have any insight to what's going on?
    • By Jr Perez
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
    • By SouthernGypsy
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
