Everythingdunes.com is an innovative and creative new company whose passion is, Literally, EVERYTHING and anything related to riding at the Sand Dunes.
Based in the Pacific Northwest, everythingdunes.com is moving ahead at full throttle creating unique products, such as infant onesies, toddler t-shirts and gift bags. Fueled by a family tradition of quads, dirt bikes, [...]
View the full article
    • By SpaceGhost
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
      Hello All...
    • By Tarak1980
