Hello everybody, Im new the forum actually it's my 1st post. I just recently purchased a used 08 trooper at the local bank. It has 535 miles and its camo. That had it as a repo, everything seems to be in really good shape. There's just 1 problem it won't run. They said it needed a ECU I purchased a ECU still nothing. All the lights work, 4 wheeldrive works, horn works, and everything else up front. The engine will crank but wont start no fuel or spark, fuel pump won't even run and the fan will not come on. Crossed over the relays to turn fans on fuel pump and get spark. Still nothing, I would really appreciate any good advise on which direction to go next.
Thanks Seth
Thanks Seth
There are some down loads of schematics and wiring diagrams available in the part & pieces thread pinned to the first several posts that may help your figure out you problem. Also if you fill out the information about yourself so we can all get to know you a little better, you may find one of us live just around the corner and can help.
Hope this will help some,
Thanks, I down loaded the schematics. I work out of town so I haven't got back yet to check it out. I updated my profile
Thanks Seth
I assume since you say your getting spark you confirmed that at the plugs,If so have you confirmed your getting fuel to the fuel rail? possible the pump now works but maybe no fuel going through the regulator.Also check fuses and key switch since both fan and fuel pump should come on when key is turned to on position.I know we have at least one other member in Ky,I went to elementry school in Florence Ky and Ryland Heights Ky.Way to many years ago.
Yes I checked fire at the plugs, I took a plug out and u could smell a little fuel on it. I checked all fuses in both boxes. There isn't a Inline fuse somewhere I might have overlooked is there? I could only get the pump and fan on when I put jumpers on the rely. I went to elementry at Edison in Catlettsburg.
I dont know of any inline fuse,could be.I do know there has been problems with the fuses themselves.If you havnt done so pull each fuse and put it back in,I have heard of some people that have had to do that because of the cheap fuses and bad connections..Was it running when you bought it or did the bank tell you the ecu was to cause of it not starting? There are many more members here that will give you more and Im sure better advise then me so dont give up.
It wasn' t running when I bought it. They had it next door at a little car lot. The mechanic is the one that told me. Which I checked also before I purchased 1. It gets power to the computer, Nothing coming out. I pulled all the fuses and checked them and then put them back. I checked the relays also. It's weird I put the jumpers in and everything works. Then put the relays back in and nothing. They don't have a roll over sensor do they? My bike has one, I wrecked it and it came on. It wouldn't let u start it. Don't know if it has 1 but that's kind of how it acts.
sethz28 I don't know whats wrong with your t2 but when you get it running send me a pm and lets go riding I have a blue t2 I live in Louisville Ky.It will be nice to ride with another joyner owner
Sounds like a plan plumber, do u have very many places to ride there?
I know a few places we can go there is mountain parkway offroad park it's not to far from you
I live fairly close to the parkway. I never knew of a offroad park there.
  • 8 years later...
    • By Xov
    • By SpaceGhost
    • By SpaceGhost
