should i buy
By diamondjfarm
Thanks.
By sxr951
parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
By mac66
By Robert Merritt
I have an older Bristers Trailwagon model TW11 with a Honda engine. I am trying to find a replacement muffler for it. It is an unusual muffler tapped in the center instead of the end with the heat shield welded on to it. Does anyone know where I can find a new one?
By sxr951
2015 massimo 700.. need cylinder bolt! it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm dont know where to find any ideas? thx
